--wrap ld functionality does not work with Init RTEMS function
Tue Apr 8 20:01:46 UTC 2008
Aitor Viana wrote:
> Hi,
>     We know that the entry point should be Init but the loader has to
>     change
>     that to be wrap_Init and real_Init.  This linker trick may only
>     substitute
>     in so many cases.   I can see where an indirect pointer through a
>     table
>     might break it.
> I modified also a little bit your example to do it through a sort of
> table, and also worked natively. I do not know whether is maybe an
> issue of the sparc-rtems cross compiler.
The real answer will be to look at what the structure has in it on
the sparc. :-D
So until tomorrow...
> Aitor
