Etherboot and PC386 BSP Question
Thu Apr 10 22:44:32 UTC 2008
Joel Sherrill wrote:
> Hi,
> I am dusting off an old Versalogic Bobcat
> 486 PC104 system to use as a test platform.
> We have generated an Etherboot floppy using
> rom-o-matic.net and the bobcat is fetching it.
> I have tried the elf executable and the output
> of bin2boot but no luck so far.
> What format does that boot?
Apparently it can boot the elf file.  Thank
you qemu for including an Etherboot ROM.
 /usr/local/bin/qemu -cpu 486 -m 8 -boot n -tftp /tftpboot/ -bootp
//bobcat.img
So my elf file runs virtually but when I
run it on the bobcat, it loads the image,
jumps to it, and then the screen goes
blank except for a hint that something
is out of sync.
Any ideas?
> Any chance the display it is working with the
> bin2boot image and the graphics mode is switching
> to something the 17" LCD can't display?
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>    Support Available             (256) 722-9985
> rtems-users mailing list
> rtems-users at rtems.com
