what exception model should I use ?
阎淼 yanmiaobest at gmail.com
Fri Apr 11 03:33:19 UTC 2008
Hi,
  I am using psim to run some startup code under gdb. I'm not using
psim to emulate a whole broad, just testing startup code. But when
executing privileged intructions like mtmsr, mtspr , the program dies
with the following message:
   cpu 1, cia 0x10000c : program interrupt - privileged instruction
   program terminated with signal ?, Unknow signal
   The grogram no longer exists.
  I test score603e bsp, it dies too, but psim bsp seem to work. I also
use the psim/tools/psim-gdb script, but the results is the same.  Are
their any special configuration options that I miss?
在 08-4-7,Joel Sherrill<joel.sherrill at oarcorp.com> 写道:
> Thomas Doerfler wrote:
> > Hi,
> > the information in the README is no longer correct (at least for
> > CVS-HEAD). I will fix this ASAP.
> > Nevertheless, the 603e is covered in the mpc6xx stuff (e.g. in the
> > mpc52xx and the mpc83xx), so you should be able to use the new exception
> > handling anyway.
> > If you would use the old exception handling stuff, your port would not
> > be compatible with any upcoming version of RTEMS.
> Here Ye! Here Ye!!
> It has been proclaimed that there is no longer an old versus new
> exception model in RTEMS. In RTEMS CVS, each port has a single
> exception model.
> As part of this proclamation, the phrases "old exceptions"
> and "new exceptions" shall henceforth be banished from the
> vocabulary of residents of the Kingdom of RTEMS. All uses of
> said phrases shall be cast into the CVS history dungeon and
> replaced by phrases such as "simple vectored" or "PIC vectored".
> The PowerPC suffered from old/new because we were too conservative
> to kill "old exception" BSPs and gave people literally 8 YEARS to convert
> before killing the "old exception" code.
> This has been a long standing area of confusion and we can move forward
> to remove this horrible terminology which ONLY impacts the PowerPC.
> I will try to write a Wiki entry on this so we can start pointing to that.
> I would hate to have to reinstate the stocks or public flogging. :-D
> --joel
> > wkr,
> > Thomas.
> > 阎淼 schrieb:
> >> Hi,
> >>    I am using rtems4.8,  and the README file is allocated at
> >> c/src/lib/libcpu/powerpc, some of the contents:
> >>    At this time, support is included for the following PowerPC
> >> family members using the new exception processing model:
> >>   + mpc505
> >>   + mpc5xx (5xx devices other than 505/509)
> >>   + mpc6xx
> >>   + mpc750
> >>   + mpc821
> >>   + mpc823 (uses mpc821 directory)
> >>   + mpc850 (uses mpc860 directory)
> >>   + mpc860
> >>   + mpc8260
> >> The following PowerPC family members are supported but
> >> still use the old exception processing model:
> >>   + ppc403
> >>   + ppc405 (uses ppc403 directory)
> >>   + ppc6xx (no libcpu support)
> >>  so I thought ppc603e is supported by old exception processing model.
> >> and If I use new exception processing, I should just use code under
> >> c/src/lib/libcpu/powerpc/new-exception, right?
> >> do I need to define any special macros ?
> >> 2008/4/6, Thomas Doerfler (nt) <Thomas.Doerfler at imd-systems.de>:
> >> Hi,
> >> this is simple, use the new one, because the "old" is no longer supported.
> >> which README did you consult? which RTEMS version are you using?
> >> wkr,
> >> Thomas.
> >>  ü schrieb:
> >> | Hi,
> >> |    I have a ppc603e based borad, which exception model should I use,
> >> | new or old?( I think it should be old exception model accroding to the
> >> | README file).
> >> |    and what macro should I define to chose between the two? and where
> >> | can I find the clock driver support, is it similar to ppc403?
> >> | _______________________________________________
> >> | rtems-users mailing list
> >> | rtems-users at rtems.com
> >> | http://rtems.rtems.org/mailman/listinfo/rtems-users
> > embedded brains GmbH
> > Thomas Doerfler           Obere Lagerstr. 30
> > D-82178 Puchheim          Germany
> > Tel. : +49-89-18 90 80 79-2
> > Fax  : +49-89-18 90 80 79-9
> > email: Thomas.Doerfler at embedded-brains.de
> > PGP public key available on request
> > Diese Nachricht ist keine gescha"ftliche Mitteilung im Sinne des EHUG.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>   Support Available             (256) 722-9985
