rtems-cvs toolchain
Ralf Corsepius ralf.corsepius at rtems.org
Wed Apr 23 08:58:51 UTC 2008
On Tue, 2008-04-22 at 17:23 -0500, Joel Sherrill wrote:
> Nigel Spon wrote:
> > On 23/04/2008, at 9:44 AM, Joel Sherrill wrote:
> >> flex?  Do you have it installed?
> > Yes:
> > [p140:RTEMSX_4.8/tools/gcc-4.3.0] frederickspon% flex --version
> > flex 2.5.33
> > Wouldn't it have to be to get the two lines:
> Yes.  Just being paranoid at a basic level.
> >> flex: fatal internal error, exec failed
> > flex: error writing output file lex.yy.c
> Did you run out of disk space? Have write permissions?
Does gmp support ueberbaum-style VPATH building?
Till's answer indicates yes, but gmp is known to be pretty bugged, so
this might vary between versions of gmp.
A likely to work work-around would be to build and install gmp
stand-alone, in advance to building GCC.
Ralf
