Leon2 RAM configuration
Wed Apr 23 18:18:47 UTC 2008
Arquer Stephane wrote:
>> just a question: do you relate to rtems 4.7.1 as distributed
>> from www.rtems.com, or a (possibly improved) version from gaisler?
> It is the www.rtems.com rtems release.
>>> There are some differences in the file
>> libbsp/sparc/shared/bspstart.c.
>>> Hard to tell if they matter.   It looks mostly cosmetic
>> except for the
>>> cache snooping setup.
> I tried to compile the bsp with  libbsp/sparc/shared/bspstart.c from
> rtems 4.7.1 but it's the same.
The size of memory is supposed to come from rdb_start.
Is that in the same location for both executables?
Does it have the same value?
