cdtest failure
Daron Chabot
daron.chabot at usask.ca
Sat Apr 26 17:45:12 UTC 2008
Trying to run cdtest.exe (rtems cvs HEAD) in qemu (0.9.1) failed with
the following output:
djc at toolbox--> qemu -no-reboot -m 128 -boot n -tftp /opt/rtems/i386-
rtems/pc386/lib/rtems-4.9/tests -bootp /cdtest.exe -serial stdio
2008-04-26 11:01:41.589 i386-softmmu[6716] KO
rtems_gxx_mutex_init
fatal error, exiting
EXECUTIVE SHUTDOWN! Any key to reboot...2008-04-26 11:01:59.995 i386-
softmmu[6716] KO
Inserting some instrumentation in "libcsupport/src/gxx_wrappers.c"
showed that the call to rtems_semaphore_create( ) was returning an
rtems_status_code of 5==RTEMS_TOO_MANY.
Changing CONFIGURE_MAXIMUM_SEMAPHORES from 1 to 2 in cdtest's
"system.h" permits the test to run to a successful conclusion.
Questions: "where is the other semaphore being consumed" ?? and "what
has changed to require more than a single semaphore" ??
-- dc
