rtems-users Digest, Vol 19, Issue 50
Teng Chee Wan Philip tcheewan at ntu.edu.sg
Tue Apr 29 07:31:04 UTC 2008
Hi,
How did you put the hello world example into the boot ROM or RAM?  The
ERC32 BSP assumes that there is a bootloader or boot code that will
initialise the stack pointer before the start code is run.
Try using a mkprom-erc32 or any mkprom utility to make the boot PROM and
boot from there.
Regards,
Philip
Date: Mon, 28 Apr 2008 18:40:16 +0100
Subject: RE: ERC32 BSP
To: <rtems-users at rtems.com>
Message-ID:
	<AD71864F31F7E94FA22FF2DDE1A228D103BA03EE at jupiter.sstl.co.uk>
Content-Type: text/plain; charset="us-ascii"
Hi,
I am trying to get RTEMS4.8 working with an erc32 but I can't get the
hello work working(newbie to RTEMS & Linux).
I have built the tools+rtems and proceeded to 'play' with the hello
world example. I am unable to get hello world working and indeed unable
to go from start.S into C world. I have checked I am proceeding through
the initialisation startup however the call to BOOT_CARD does not run
correctly and probably results in a trap (still looking). I have checked
the HW config, which matches the actual HW I have but however I am
unable to run the application.
Any pointers ideas gratefully received.
Neil Mayes
Software Engineer
SB +44 (0)1483 803803
DD +44 (0)1483 803878
FX +44 (0)1483 803804
Surrey Satellite Technology Ltd
Tycho House
20 Stephenson Road
Surrey Research Park
Guildford
Surrey
GU2 7YE
rtems-users mailing list
http://rtems.rtems.org/mailman/listinfo/rtems-users
End of rtems-users Digest, Vol 19, Issue 50
