ERC32 BSP
Teng Chee Wan Philip tcheewan at ntu.edu.sg
Tue Apr 29 10:04:19 UTC 2008
You can also refer to the following link
http://rtems.org/wiki/index.php/SparcBSPStartup
Regards,
Philip
-----Original Message-----
Sent: Tuesday, April 29, 2008 5:57 PM
To: Teng Chee Wan Philip
Subject: RE: rtems-users Digest, Vol 19, Issue 50
Hi Philip,
> From: Teng Chee Wan Philip [mailto:tcheewan at ntu.edu.sg]
> Sent: 29 April 2008 08:31
> To: Neil Mayes
> Cc: rtems-users at rtems.org
> Hi,
> How did you put the hello world example into the boot ROM or RAM?  The
> ERC32 BSP assumes that there is a bootloader or boot code
> that will initialise the stack pointer before the start code is run.
I have a bootloader that allows the RAM image to be sucked from the UART
to a specified location (0x02000000) and then allows the code to be
executed. I was under the impresseion a BSP should assume it's coming
from cold start and make sure it's world is setup as it would like it.
> Try using a mkprom-erc32 or any mkprom utility to make the
> boot PROM and boot from there.
Should the BSP not re-initialise the registers as it would want them?
> Regards,
> Philip
Regards,
Neil
