exceptions in RAM was Re: What is "no" application? nm?
Till Straumann
strauman at slac.stanford.edu
Tue Apr 1 18:42:22 UTC 2008
Joel Sherrill wrote:
> Till Straumann wrote:
>> Ralf Corsepius wrote:
>>> On Tue, 2008-04-01 at 10:39 +0300, Leon Pollak wrote:
>>>> On Monday, 31 בMarch 2008, Ralf Corsepius wrote:
>>>>> I am not using kdevelop - Last time I tried, kdevelop could not
>>>>> handle
>>>>> cross-compilation :/
>>>> It handles cross-compilation really good for some (long) time.
>>>> It is very fast and handy.
>>>> A bit clumsy debugger interface, but I recommend it.
>>>>>> Still, I see rather many changes in the basic libcpu code, BSP
>>>>>> and some
>>>>>> things do not work, although worked in 4.7.
>>>>>> Still struggling with them, and if somebody needs my experience...
>>>>> My advise: Dump kdevelop.
>>>> Thanks...:) Will not follow it :))
>>> Choose your poison.
>>> To me, kdevelop is a semi-functional "greasy kid toy" - Last time I
>>> checked, it had not been able to import foreign projects, produced junk
>>> auto*tool support files and did only support one target-at-time
>>> compilation.
>>>> For example, there was no usage of Cpu_table.exceptions_in_RAM in
>>>> none of
>>>> mpc8xxx BSPs.
>> IIRC, psim is the only target using 'exceptions_in_RAM == FALSE'.
>> Note, however, that the name is misleading. It only refers to the
>> address where the
>> exception vectors are (in_RAM=TRUE -> zero, in_RAM=FALSE -> high
>> address).
>> However, the (IMHO not so-) wonderful 'new-exceptions' model *always*
>> requires
>> the vector table to be writable (met by psim, of course) so the
>> vector table
>> cannot be in ROM...
> Thanks. Isn't this the deficiency Thomas would like to see resolved?
I think so.
T
>> HTH
>> -- Tiill
>>> This has nothing to do with your current issue.
>>> The powerpc guys (Thomas, Till, Joel) are the persons to answer.
>>> Ralf
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
