GCOV
Chris Johns
chrisj at rtems.org
Wed Apr 2 22:21:12 UTC 2008
Aitor Viana wrote:
> Hi everybody,
> Does anybody knows how RTEMS is handling (if it does) test coverage
> analysis in the embedded platforms? either for applications or RTEMS itself?
> I am making that question because I started not to far ago to write
> something allowing embedded SW coverage analysis by means of gcov. I
> already get something running for ERC32 and LEON2 allowing the coverage
> analysis for one source file...and I am about continue (in the spare
> time) the development to address the full implementation.
> When you want to perform gcov analysis, you compile the source files
> with the "-fprofile-arcs" and "-ftest-coverage" flags. GCC then will
> instrument the code adding the line counting and hooks to the "libgcov"
> library, which is the one retrieving the coverage information after
> execution.
> The calls being hooked by gcc are empty, so only doing this, the SW
> would actually would do nothing when executing (we would not retrieve
> the coverage information).
> This needs to be done by the libgcov library, which needs to be linked
> with the already hooked software.
> This library is the one I am implementing for embedded systems, as the
> normal one just dumps the coverage information in files (not good for
> embedded systems)
> Basically what I am planning is to send the .gcda (is the file which
> will hold the coverage analysis data) through for instance a serial
> line, though I think will be to slow interface. That's why I am also
> planning to support any other high speed comm. links, like Ethernet,
> spacewire, etc. An also let the gcov library software being as scalable
> and portable as possible.
> The idea is to have a client in the embedded target sending the
> information to the host where a server is being executed and is putting
> together everything again in files. (.gcda files). Those files will be
> then analyzed by gcov after execution.
> I think, this could be a tool that might be integrated within RTEMS
> distribution for application testing purposes. Even more, it may also be
> tuned to support RTEMS overage analysis....
> I am gonna do it anyway...so if RTEMS want benefit from the tool...just
> let me know.
Yes I think this would be useful. Have you seen the GSOC project relating to
the real time tracing ? Please check the RTEMS Wiki. The Capture Engine will
contain the buffering and transport code so it would be nice to have your code
use this software. We want to a way for user to add their own transport if the
standard ones in RTEMS are not suitable.
I would consider the GCOV data as a single trace point of a specific class.
The Capture Engine can provide a call for you to place the data into the
buffer and to transport it to host machine. Here we can extract that data for
you to handle with the existing GCOV tools. It will also handle the overflow
issues, an issue with embedded systems and slow transports.
Please note this project depends on GSOC acceptance so here hoping we get it.
Regards
