Building difficulties under OSX
Daron Chabot
daron.chabot at usask.ca
Fri Apr 4 00:18:05 UTC 2008
Nigel Spon wrote:
>> /tmp/trial/bin should contain your cross-platform tools
>> (powerpc-rtems4.8-gcc, powerpc-rtems4.8-ld, etc)
> Is this before I call make, or after? I can't tell if the --prefix
> option specifies where to find the tools, or where RTEMS will be built.
> The documentation says its the install-point, but it doesn't say of
> what. I'll try making it where the tools are and see what happens...
The --prefix option specifies where to install the products of a "make".
Have you added "/tmp/trial/bin" to your PATH ??
Maybe we should back up a few steps...
Exactly what did you do to install binutils,gcc,and newlib ? What
versions were used, etc ?
-- dc
