Intermixing source code with disassembly
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Apr 4 13:09:41 UTC 2008
Teng Chee Wan Philip wrote:
> Hi,
> I was trying to disassemble my executable and intermix source code
> with the disassembly, but objdump did not managed to find the source
> code. Does anyone have any suggestions why this could be so? Are
> there any limitations on objdump or specific way that objdump uses to
> search for the source code?
> $ sparc-rtems4.8-objdump -d -S app.exe
Is app.exe stripped or in some other format that doesn't include symbols?
Has the .exe been moved from its build location? Sometimes you have to
tell objdump (and gdb) where the real source is located. Use the --source
option.
I use objdump to do what you are doing and it does work. Here's an example
fragment:
RTEMS_INLINE_ROUTINE void _Chain_Initialize_empty(
Chain_Control *the_chain
the_chain->first = _Chain_Tail(the_chain);
2003a00: c2 20 7f fc st %g1, [ %g1 + -4 ]
2003a04: 82 00 7f fc add %g1, -4, %g1
the_chain->permanent_null = NULL;
the_chain->last = _Chain_Head(the_chain);
2003a08: c2 20 60 08 st %g1, [ %g1 + 8 ]
> Regards,
> Philip
