--wrap ld functionality does not work with Init RTEMS function
Tue Apr 8 20:41:51 UTC 2008
Aitor Viana wrote:
> Hi,
>     The real answer will be to look at what the structure has in it on
>     the sparc. :-D
>     So until tomorrow...
> maybe I can tell you
> In leon2 the initialization_tasks[] is
> rtems_initialization_tasks_table Initialization_tasks[] = {
>   { CONFIGURE_INIT_TASK_NAME,
>     CONFIGURE_INIT_TASK_STACK_SIZE,
>     CONFIGURE_INIT_TASK_PRIORITY,
>     CONFIGURE_INIT_TASK_ATTRIBUTES,
>     CONFIGURE_INIT_TASK_ENTRY_POINT,
>     CONFIGURE_INIT_TASK_INITIAL_MODES,
>     CONFIGURE_INIT_TASK_ARGUMENTS
That's the C code.  Now what is the actual value in target memory
for the address for CONFIGURE_INIT_TASK_ENTRY_POINT?
We need to know the output of ld as it shows up on the target.
> Taking into account that the configuration is simply:
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_MAXIMUM_TASKS     10
> #define CONFIGURE_INIT_TASK_PRIORITY    1
> #define CONFIGURE_INIT_TASK_INITIAL_MODES   RTEMS_PREEMPT
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #include <rtems/confdefs.h>
> The final intialization_tasks[] shoud be:
>   { rtems_build_name( 'U', 'I', '1', ' ' ),                    //
> default value
>     RTEMS_MINIMUM_STACK_SIZE,                // default value
>     1,
>     RTEMS_DEFAULT_ATTRIBUTES,               // default values
>     Init,
> // default value
>     RTEMS_PREEMPT,
>     0
> // default value
