More build oddities
Nigel Spon
nigel at adi.co.nz
Wed Apr 9 21:35:31 UTC 2008
Sorry, was away for a couple of days there. Thanks for all the
commentary, I'm learning a lot here.
I'm building on an Intel Mac under 10.5 (Leopard). I'm using autoconf
2.61 and automake 1.10. They are both in /usr/bin. I'm using absolute
paths in my build scripts which are passed to me by the XCode
environment.
Here is somewhat more of the log:
Making all in powerpc-rtems4.8/c
Making all in .
Configuring RTEMS_BSP=virtex
checking for gmake... no
checking for make... make
checking build system type... i386-apple-darwin9.2.2
checking host system type... powerpc-unknown-rtems4.8
checking rtems target cpu... powerpc
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /Users/frederickspon/Documents/
RTEMSX_4.8/RTEMS_Xcode/../tools/rtems-4.8.0/c/src/../../install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... no
checking for awk... awk
checking whether make sets $(MAKE)... yes
checking for powerpc-rtems4.8-strip... powerpc-rtems4.8-strip
checking whether to enable maintainer-specific portions of
Makefiles... no
checking for RTEMS_BSP... virtex
checking for /Users/frederickspon/Documents/RTEMSX_4.8/RTEMS_Xcode/../
tools/rtems-4.8.0/c/src/../../bspkit/powerpc/*/cfg/virtex.cfg... no
tools/rtems-4.8.0/c/src/../../make/custom/virtex.cfg... yes
checking whether BSP supports networking... yes
checking whether CPU supports libposix... yes
checking for rpcgen... rpcgen
configure: setting up make/custom
configure: creating make/virtex.cache
checking for RTEMS_CPU_MODEL... ppc405
checking for RTEMS_BSP_FAMILY... (cached) virtex
checking for CPU_CFLAGS... (cached) -mcpu=403 -Dppc405 -Dvirtex
checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g -fno-keep-inline-
functions
checking for style of include used by make... GNU
checking for powerpc-rtems4.8-gcc... /Developer/usr/bin/cc
checking for powerpc-rtems4.8-gcc... (cached) /Developer/usr/bin/cc
checking for C compiler default output file name...
configure: error: C compiler cannot create executables
See `config.log' for more details.
I would guess that the 'config.log' referred to is the one in b-rtems/
powerpc-rtems4.8/c/virtex, where I find:
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by rtems-c-src configure 4.8.0, which was
generated by GNU Autoconf 2.61. Invocation command line was
$ /Users/frederickspon/Documents/RTEMSX_4.8/RTEMS_Xcode/../tools/
rtems-4.8.0/c/src/configure --prefix=/Users/frederickspon/Documents/
RTEMSX_4.8/RTEMS_Xcode/Build~~ --host=powerpc-rtems4.8 --build=i386-
apple-darwin9.2.2 --target=powerpc-rtems4.8 --disable-sim --enable-cxx
--with-target-subdir=powerpc-rtems4.8 --exec-prefix=/Users/
frederickspon/Documents/RTEMSX_4.8/RTEMS_Xcode/Build~~/powerpc-
rtems4.8 --includedir=/Users/frederickspon/Documents/RTEMSX_4.8/
RTEMS_Xcode/Build~~/powerpc-rtems4.8/include build_alias=i386-apple-
darwin9.2.2 host_alias=powerpc-rtems4.8 target_alias=powerpc-rtems4.8
--with-project-root=../../ --with-project-top=../../
## Platform. ##
hostname = p140.adi.co.nz
uname -m = i386
uname -r = 9.2.2
uname -s = Darwin
uname -v = Darwin Kernel Version 9.2.2: Tue Mar 4 21:17:34 PST 2008;
root:xnu-1228.4.31~1/RELEASE_I386
/usr/bin/uname -p = i386
/bin/uname -X = unknown
/bin/arch = unknown
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = Mach kernel version:
Kernel configured for up to 2 processors.
2 processors are physically available.
2 processors are logically available.
Processor type: i486 (Intel 80486)
Processors active: 0 1
Primary memory available: 2.00 gigabytes
Default processor set: 65 tasks, 229 threads, 2 processors
Load average: 0.71, Mach factor: 1.39
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /Users/frederickspon/Documents/RTEMSX_4.8/RTEMS_Xcode/Build~~/bin
PATH: /Developer/usr/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/sbin
PATH: /sbin
## Core tests. ##
configure:1869: checking for gmake
configure:1899: result: no
configure:1869: checking for make
configure:1885: found /Developer/usr/bin/make
configure:1896: result: make
configure:1971: checking build system type
configure:1989: result: i386-apple-darwin9.2.2
configure:2012: checking host system type
configure:2027: result: powerpc-unknown-rtems4.8
configure:2049: checking rtems target cpu
configure:2084: result: powerpc
configure:2103: checking for a BSD-compatible install
configure:2159: result: /usr/bin/install -c
configure:2170: checking whether build environment is sane
configure:2213: result: yes
configure:2241: checking for a thread-safe mkdir -p
configure:2280: result: /Users/frederickspon/Documents/RTEMSX_4.8/
configure:2293: checking for gawk
configure:2323: result: no
configure:2293: checking for mawk
configure:2293: checking for nawk
configure:2293: checking for awk
configure:2309: found /usr/bin/awk
configure:2320: result: awk
configure:2331: checking whether make sets $(MAKE)
configure:2352: result: yes
configure:2414: checking for powerpc-rtems4.8-strip
configure:2430: found /Users/frederickspon/Documents/RTEMSX_4.8/
RTEMS_Xcode/Build~~/bin/powerpc-rtems4.8-strip
configure:2441: result: powerpc-rtems4.8-strip
configure:2522: checking whether to enable maintainer-specific
portions of Makefiles
configure:2531: result: no
configure:2591: checking for RTEMS_BSP
configure:2605: result: virtex
configure:2652: checking for /Users/frederickspon/Documents/RTEMSX_4.8/
RTEMS_Xcode/../tools/rtems-4.8.0/c/src/../../bspkit/powerpc/*/cfg/
virtex.cfg
configure:2663: result: no
RTEMS_Xcode/../tools/rtems-4.8.0/c/src/../../make/custom/virtex.cfg
configure:2657: result: yes
configure:2681: checking whether BSP supports networking
configure:2699: result: yes
configure:2744: checking whether CPU supports libposix
configure:2762: result: yes
configure:2773: checking for rpcgen
configure:2789: found /Developer/usr/bin/rpcgen
configure:2800: result: rpcgen
configure:2809: setting up make/custom
configure:2871: checking for /Users/frederickspon/Documents/RTEMSX_4.8/
virtex.cfg
configure:2882: result: no
configure:2876: result: yes
configure:2903: creating make/virtex.cache
configure:2911: checking for RTEMS_CPU_MODEL
configure:2918: result: ppc405
configure:2925: checking for RTEMS_BSP_FAMILY
configure:2932: result: virtex
configure:2939: checking for CPU_CFLAGS
configure:2946: result: -mcpu=403 -Dppc405 -Dvirtex
configure:2950: checking for CFLAGS_OPTIMIZE_V
configure:2957: result: -O2 -g -fno-keep-inline-functions
configure:2978: checking for style of include used by make
configure:3006: result: GNU
configure:3038: checking for powerpc-rtems4.8-gcc
configure:3065: result: /Developer/usr/bin/cc
configure:3086: checking for powerpc-rtems4.8-gcc
configure:3113: result: /Developer/usr/bin/cc
configure:3391: checking for C compiler version
configure:3398: /Developer/usr/bin/cc --version >&5
i686-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5465)
Copyright (C) 2005 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There
is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
configure:3401: $? = 0
configure:3408: /Developer/usr/bin/cc -v >&5
Using built-in specs.
Target: i686-apple-darwin9
Configured with: /var/tmp/gcc/gcc-5465~16/src/configure --disable-
checking -enable-werror --prefix=/usr --mandir=/share/man --enable-
languages=c,objc,c++,obj-c++ --program-transform-name=/^[cg][^.-]*$/s/
$/-4.0/ --with-gxx-include-dir=/include/c++/4.0.0 --with-slibdir=/usr/
lib --build=i686-apple-darwin9 --with-arch=apple --with-tune=generic --
host=i686-apple-darwin9 --target=i686-apple-darwin9
Thread model: posix
gcc version 4.0.1 (Apple Inc. build 5465)
configure:3411: $? = 0
configure:3418: /Developer/usr/bin/cc -V >&5
gcc-4.0: argument to `-V' is missing
configure:3421: $? = 1
configure:3444: checking for C compiler default output file name
configure:3471: /Developer/usr/bin/cc -mcpu=403 -Dppc405 -Dvirtex -O2 -
g -fno-keep-inline-functions conftest.c >&5
cc1: error: invalid option 'cpu=403'
configure:3474: $? = 1
configure:3512: result:
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME "rtems-c-src"
| #define PACKAGE_TARNAME "rtems-c-src"
| #define PACKAGE_VERSION "4.8.0"
| #define PACKAGE_STRING "rtems-c-src 4.8.0"
| #define PACKAGE_BUGREPORT "http://www.rtems.org/bugzilla"
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure:3519: error: C compiler cannot create executables
Heres the directory in the PATH where it should have found the
compiler, and the compiler appears to be there
[p140:~] frederickspon% ls /Users/frederickspon/Documents/RTEMSX_4.8/
cklength powerpc-rtems4.8-difftest powerpc-rtems4.8-ranlib
eolstrip powerpc-rtems4.8-g++ powerpc-rtems4.8-readelf
install-if-change powerpc-rtems4.8-gcc powerpc-rtems4.8-size
packhex powerpc-rtems4.8-gcc-4.1.1 powerpc-rtems4.8-sorttimes
powerpc-rtems4.8-addr2line powerpc-rtems4.8-gccbug powerpc-rtems4.8-
strings
powerpc-rtems4.8-ar powerpc-rtems4.8-gcov powerpc-rtems4.8-strip
powerpc-rtems4.8-as powerpc-rtems4.8-ld rtems-bin2c
powerpc-rtems4.8-c++ powerpc-rtems4.8-nm unhex
powerpc-rtems4.8-c++filt powerpc-rtems4.8-objcopy
powerpc-rtems4.8-cpp powerpc-rtems4.8-objdump
Wi not trei a holiday in Sweden this yer?
Michael Hamel
ADInstruments Ltd, Dunedin, NZ
