Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Fri Apr 11 06:42:12 UTC 2008
Hi,
unfortunately you provide only very limited info. I understand that you
use RTEMS-4.6.6 (which is very outdated) and you use some supported
architecture with interrupts.
Some questions:
- which architecture/BSP do you use?
- what do you do to get printf to fail?
In many RTEMS systems it is normal, that the processor reaches the Idle
task while output is pending, because the serial interface will provide
an interrupt whenever a new character can be written to the serial device.
wkr,
Thomas Doerfler.
fall4ufeng schrieb:
> hi all:
>         The printf function outside the interrupt service function can't
> work normally( the routine run into __CPU_Thread_Idle_body function
> ) after the interrupte was enabled.
>    My rtems's version is 4.6.6.
>    Can someone tell me how to fix this ?
>    Thanks a lot .
> 2008-04-11
> fall4ufeng
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
