How to retrieve an interface's MAC address
Arnout Vandecappelle
arnout at mind.be
Mon Apr 14 13:17:23 UTC 2008
Chris Johns wrote:
> Arnout Vandecappelle wrote:
>> Hoi,
>> I need to get the network interface's MAC address from my
>> application. According to the Wiki (Obtaining_Interface_Information),
>> this can be
>> obtained by ioctl'ing for SIOCGIFADDR. However, this gives the IP
>> address (ether_ioctl does return the MAC address, but it never gets
>> there as it is intercepted by in_control). As far as I can see, there
>> is no simple way to retrieve the MAC address from the application. (You
>> can get it from within the networking stack one you have the struct
>> ifnet, like is done in the DHCP client, but this is not supposed to be
>> accessible from the application.)
>> Is there a way to retrieve it that I missed?
> There is the sysctl interface which is used by net-snmp to provide
> details about an interface. Not a nice interface but it does work.
> What about the SIOCGIFCONF ioctl ? See
> cpukit/libnetworking/libc/getifaddrs.c for an example of its use. Look
> for the socket part of the code. Check 'ifconf' in
> cpukit/libnetworking/net/if.c.
> Please update the Wiki if you get a solution.
It took me a week to implement this, but here it goes. I updated the
Wiki as well.
Since I'm working with a 4.6.99 version, could someone try this on the
current RTEMS?
Regards,
Arnout
Arnout Vandecappelle arnout at mind be
Senior Embedded Software Architect +32-16-286540
Mind Embedded Development (an Essensium division)
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20080414/d0d3703c/attachment-0001.bin>
