GCC Warning on MIPS
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 22 15:01:39 UTC 2008
Ralf Corsepius wrote:
> On Tue, 2008-04-22 at 09:25 -0500, Joel Sherrill wrote:
>> Ralf,
>> I know neither of us go digging through build
>> logs when the build works, but I came across this
>> warning building GCC SVN trunk targeting mips-rtems4.9
>> In file included from ./tm.h:10,
>> from ../../gcc/gcc/gencheck.c:24:
>> ../../gcc/gcc/config/rtems.h:21:1: warning: "NO_IMPLICIT_EXTERN_C" redefined
>> In file included from ./tm.h:8,
>> Not critical but is repeated about 10,000 times. :-D
>> I think the #define NO_IMPLICIT_EXTERN_C in gcc/config/rtems.h
>> needs an ifndef or an undef added.
>> What do you think we need to do?
> Hmm, do you have this patch below applied?
> diff -Naur gcc-4.3.0.orig/gcc/config/mips/elf.h gcc-4.3.0/gcc/config/mips/elf.h
> --- gcc-4.3.0.orig/gcc/config/mips/elf.h 2007-08-02 12:49:31.000000000 +0200
> +++ gcc-4.3.0/gcc/config/mips/elf.h 2008-03-06 16:22:30.000000000 +0100
> @@ -48,6 +48,4 @@
> #undef ENDFILE_SPEC
> #define ENDFILE_SPEC "crtend%O%s crtn%O%s"
> -#define NO_IMPLICIT_EXTERN_C 1
> #define HANDLE_PRAGMA_PACK_PUSH_POP 1
> This is a general bug in the mips port (I _know_ it is), but ...
> upstream refuses to apply it, which forces us to keep it as a separate
> patch :)
In many cases throughout the gcc config files, they just undef
the previous one and redefine. In the above, ENDFILE_SPEC
is done that way. Three of the five definitions in config/rtems.h
have an undef in front of them. Would it be so bad to just
do that for the rest of the ones in rtems.h?
> Ralf
