GCC Warning on MIPS
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 22 21:22:56 UTC 2008
Ralf Corsepius wrote:
>>>>> On Tue, 2008-04-22 at 09:25 -0500, Joel Sherrill wrote:
>>>>>> Ralf,
>>>>>> I know neither of us go digging through build
>>>>>> logs when the build works, but I came across this
>>>>>> warning building GCC SVN trunk targeting mips-rtems4.9
>>>>>> In file included from ./tm.h:10,
>>>>>> from ../../gcc/gcc/gencheck.c:24:
>>>>>> ../../gcc/gcc/config/rtems.h:21:1: warning: "NO_IMPLICIT_EXTERN_C" redefined
>>>>>> In file included from ./tm.h:8,
>>>>>> Not critical but is repeated about 10,000 times. :-D
>>>>>> I think the #define NO_IMPLICIT_EXTERN_C in gcc/config/rtems.h
>>>>>> needs an ifndef or an undef added.
>>>>>> What do you think we need to do?
>>>>> Hmm, do you have this patch below applied?
>>>>> diff -Naur gcc-4.3.0.orig/gcc/config/mips/elf.h gcc-4.3.0/gcc/config/mips/elf.h
>>>>> --- gcc-4.3.0.orig/gcc/config/mips/elf.h 2007-08-02 12:49:31.000000000 +0200
>>>>> +++ gcc-4.3.0/gcc/config/mips/elf.h 2008-03-06 16:22:30.000000000 +0100
>>>>> @@ -48,6 +48,4 @@
>>>>> #undef ENDFILE_SPEC
>>>>> #define ENDFILE_SPEC "crtend%O%s crtn%O%s"
>>>>> -#define NO_IMPLICIT_EXTERN_C 1
>>>>> #define HANDLE_PRAGMA_PACK_PUSH_POP 1
>>>>> This is a general bug in the mips port (I _know_ it is), but ...
>>>>> upstream refuses to apply it, which forces us to keep it as a separate
>>>>> patch :)
>>>> In many cases throughout the gcc config files, they just undef
>>>> the previous one and redefine. In the above, ENDFILE_SPEC
>>>> is done that way. Three of the five definitions in config/rtems.h
>>>> have an undef in front of them. Would it be so bad to just
>>>> do that for the rest of the ones in rtems.h?
>>> Why should they?
>>> Wrt. to NO_IMPLICIT_EXTERN_C, to me this doesn't make any sense at all.
>> Maybe not but there is precedence for it. The shared
>> config files for a number of other OSes do this:
>> [joel at iceland config]$ grep -r NO_IMPLICIT_EXTERN_C .| grep ifndef |
>> grep -v .svn
>> ./lynx.h:#ifndef NO_IMPLICIT_EXTERN_C
>> [joel at iceland config]$ grep -r NO_IMPLICIT_EXTERN_C .| grep undef| grep
>> -v .svn
>> ./netbsd.h:#undef NO_IMPLICIT_EXTERN_C
>> ./rs6000/sysv4.h:#undef NO_IMPLICIT_EXTERN_C
>> ./i386/sco5.h:#undef NO_IMPLICIT_EXTERN_C
>> ./freebsd.h:#undef NO_IMPLICIT_EXTERN_C
>> ./vx-common.h:#undef NO_IMPLICIT_EXTERN_C
>> ./sparc/openbsd64.h:#undef NO_IMPLICIT_EXTERN_C
> And where would be the sense behind this?
> We want to force NO_IMPLICIT_EXTERN_C.
> The bug is in mips/elf.h. This file belongs to the mips backend.
> This file simply is broken by defining an OS specific flag such as
> Cf. how we set up _all_ other targets. The only one behaving differently
> is this broken mips file.
Then how about proposing a patch for the mips/elf.h file
to gcc?
> Ralf
