4.8.0 fails to build (configure: error: no acceptable cc found in $PATH)
rtwas
rtwas at comcast.net
Thu Aug 7 06:44:36 UTC 2008
Hello,
"make" fails for some reason. I'm not sure if this is a 64bit/32bit
problem or a naming problem.
os: SuSE10.2 (amd64)
assumptions:
build path: /usr/local/packages/rtos/rtems/4.8/4.8.0
rtems src path: /usr/local/packages/rtos/rtems/4.8/4.8.0/rtems-4.8.0
tools path: /opt/rtems-4.8/bin
tools packages installed:
rtems-4.8-binutils-common-2.18-3.suse10.2.i586.rpm
rtems-4.8-gcc-common-4.2.4-30.suse10.2.i586.rpm
rtems-4.8-gdb-common-6.8-1.suse10.2.i586.rpm
rtems-4.8-newlib-common-1.15.0-30.suse10.2.i586.rpm
rtems-4.8-powerpc-rtems4.8-binutils-2.18-3.suse10.2.i586.rpm
rtems-4.8-powerpc-rtems4.8-gcc-4.2.4-30.suse10.2.i586.rpm
rtems-4.8-powerpc-rtems4.8-gdb-6.6-12.suse10.2.i586.rpm
rtems-4.8-powerpc-rtems4.8-newlib-1.15.0-30.suse10.2.i586.rpm
procedure:
- >cd /usr/local/packages/rtos/rtems/4.8/4.8.0; mkdir
rtems-4.8.0-mvme5500.080608.00-build
- >cd rtems-4.8.0-mvme5500.080608.00-build
- >../rtems-4.8.0/configure --target=powerpc-rtems
--enable-rtemsbsp=mvme5500
**seems to configure ok
- >make ("make all" fails: "make: *** No rule to make target `all'.
Stop.")
result:
checking whether to enable maintainer-specific portions of
Makefiles... no
checking for RTEMS_BSP... mvme5500
checking for
../../../../rtems-4.8.0/c/src/../../bspkit/powerpc/*/cfg/mvme5500.cfg... no
checking for
../../../../rtems-4.8.0/c/src/../../make/custom/mvme5500.cfg... yes
checking whether BSP supports networking... yes
checking whether CPU supports libposix... yes
checking for rpcgen... rpcgen
configure: setting up make/custom
checking for
checking for
configure: creating make/mvme5500.cache
gmake[3]: Entering directory
`/usr/local/packages/rtos/rtems/4.8/4.8.0/rtems-4.8.0-mvme5500.080608.00-build/powerpc-rtems/c/mvme5500'
gmake[3]: Leaving directory
checking for RTEMS_CPU_MODEL... mpc7455
checking for RTEMS_BSP_FAMILY... (cached) mvme5500
checking for CPU_CFLAGS... (cached) -fno-strict-aliasing -mcpu=7450
-Dmpc7455 -mno-altivec -mabi=altivec -mvrsave=no -mmultiple -mstring
-mstrict-align
checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
checking for style of include used by gmake... GNU
checking for powerpc-rtems-gcc... no
gmake[2]: *** [mvme5500] Error 1
gmake[2]: Leaving directory
`/usr/local/packages/rtos/rtems/4.8/4.8.0/rtems-4.8.0-mvme5500.080608.00-build/powerpc-rtems/c'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
make: *** [all-recursive] Error 1
- >which powerpc-rtems4.8-gcc
/opt/rtems-4.8/bin/powerpc-rtems4.8-gcc
I thought it might be a confused "configure" script so I also tried
starting over and reconfiguring with:
<../rtems-4.8.0/configure --target=powerpc-rtems
--enable-rtemsbsp=mvme5500 --program-prefix=powerpc-rtems4.8->
with the same results.
Help appreciated.
Robert W.
