4.8.0 fails to build (configure: error: no acceptable cc found in $PATH)
Fri Aug 8 05:07:52 UTC 2008
rtwas wrote:
> Hello,
> If you look at my post again, you'll see that I do a "which" command.
> The results of that command indicate that I have already compiled with this
> requirement.
>> > - >which powerpc-rtems4.8-gcc
>> > /opt/rtems-4.8/bin/powerpc-rtems4.8-gcc
Yes you did. Sorry about that.
You will need to look into the config.log to find the reason why.
Regards
