4.8.0 fails to build (configure: error: no acceptable cc found in $PATH)
Ralf Corsepius ralf.corsepius at rtems.org
Fri Aug 8 05:35:57 UTC 2008
On Fri, 2008-08-08 at 15:07 +1000, Chris Johns wrote:
> rtwas wrote:
> > Hello,
> > If you look at my post again, you'll see that I do a "which" command.
> > The results of that command indicate that I have already compiled with this
> > requirement.
> >> > - >which powerpc-rtems4.8-gcc
> >> > /opt/rtems-4.8/bin/powerpc-rtems4.8-gcc
> Yes you did. Sorry about that.
> You will need to look into the config.log to find the reason why.
The OP is configuring with ... --target=powerpc-rtems
Provided the toolchains he is trying to use, this should be
--target=powerpc-rtems4.8
Ralf
