[Fwd: Mail delivery failed: returning message to sender]/Re: 4.8.0 fails to build (configure: error: no acceptable cc found in $PATH)
rtwas
rtwas at comcast.net
Sat Aug 9 22:50:28 UTC 2008
Hello,
Sorry about the spam-filter. Comcast did it without my knowing. I'm
trying to figure out
how to get it solved.
> Provided the toolchains he is trying to use, this should be
> --target=powerpc-rtems4.8
> Ralf
This fixed it. The build was looking for tool-names without the "4.8" part.
Thanks for the help.
Robert W.
Ralf Corsepius wrote:
> RTWAS,
> Your wanna-be spam filter is blocking valid email addresses (mine)
> Please stop using invalid email addresses to post on public mailing
> lists.
> Also please understand that I will stop to communicate to people to
> whom I am not able to communicate with.
> Ralf
> > rtwas wrote:
> >> Hello,
> >> If you look at my post again, you'll see that I do a "which"
> >> command.
> >> The results of that command indicate that I have already compiled
> >> with this requirement.
> >>>> - >which powerpc-rtems4.8-gcc
> >>>> /opt/rtems-4.8/bin/powerpc-rtems4.8-gcc
> > Yes you did. Sorry about that.
> > You will need to look into the config.log to find the reason why.
> The OP is configuring with ... --target=powerpc-rtems
> Ralf
