POSIX FIFO/pipe
Wei Shen cquark at gmail.com
Tue Aug 12 15:07:14 UTC 2008
Hi Joel,
Are you less busy now? If so could you pls help on my questions below.
On 7/31/08, Wei Shen <cquark at gmail.com> wrote:
> Hi Joel,
> Oh, I did not know you were busy. I still have several questions. They are
> not urgent. I can wait until you are free.
> Hoping your wife get better soon.
> Wei Shen
> On 7/26/08, Wei Shen <cquark at gmail.com> wrote:
Which location is prefered for pipe source files?
Currently, cpukits/libfs/pipe/.
Any document on how to finish all the configuration scripts and makefiles,
and to add necessary configuration items?
Which location is prefered for pipe test code?
testsuites/psxtest/ ?
Is psxtest ported from somewhere?
I feel it is too consuming to design and implement testcases oneself.
At which level should the pipe module be initialized?
Currently, I initialize the pipe module at the initialization of each
FS supports it (IMFS_initialize_support to be more specific).
In my code, I always carefully assume rtems_semaphore_obtain and
rtems_barrier_wait may fail (not timeout or destroyed). Is that necessary?
Thanks,
Wei
URL: <http://lists.rtems.org/pipermail/users/attachments/20080812/91e80b4b/attachment.html>
