Add file to Makefile
Ralf Corsepius ralf.corsepius at rtems.org
Sat Aug 16 03:42:31 UTC 2008
On Sat, 2008-08-16 at 01:08 +0300, Leon Pollak wrote:
> Hello, all.
> Please, where can I read about how can I add an *.h file to the BSP build
> tree.
Inside of the autotools' fine manuals.
In your case, reading about *_HEADERS and *_SOURCES in "info
automake" (rsp. http://sources.redhat.com/automake) is your friend.
As an introduction to the autotools, esp. for complete new-comers,
reading the "Goat book" (http://sources.redhat.com/autobook) is still
worth it.
> I searched bsp_howto.pdf, wiki - did not find.
> Tried to add it to Makefile.am - does not help, it is not copied to the build
> tree...:-(
> Sorry to disturb, but these autotools are the great mystery for me...:-(
... your question is a mystery to me :-)
My guess is you are talking about "preinstalling" a header inside of the
build tree?
This question would only be marginally related to the autotools, it's an
RTEMS's build-system "feature" (More precisely: a hack to work-around
some issues with RTEMS historical source-tree structure/layout).
In this case, the detailed answer would be:
1. Edit your changes into your BSP's Makefile.am
Add your *.h to the *_HEADERS variable in your BSP's Makefile.am,
corresponding to the location where you want to install it to.
e.g.
# cd c/src/lib/libbsp/<cpu>/<bsp>
Invoke an editor and add something similar to this to Makefile.am
include_foo_HEADERS += <source-subdir>/bar.h
2. Recreate "preinstall.am"
# <top_sourcedir>/bootstrap -p
3. Regenerate autotool generated files:
# <top_sourcedir>/bootstrap -r
Note 1: All these steps are a one-time effort.
Afterwards, when building RTEMS, with maintainer-mode enabled (configure
--enable-maintainer-mode), all generated files will be updated
automatically, when necessary during the next "make run".
Note 2: When modifying an existing BSP, steps 2.+ 3. are optional and
will automatically be performed during the next "make run" when having
configured your build-tree with --enable-maintainer-mode.
Ralf
