Blackfin port footprint bss > 500K ?
Devin Butterfield devin.butterfield at gmail.com
Sun Aug 17 07:15:57 UTC 2008
Hi folks,
Using the cvs head RTEMS, binutils 2.18, gcc-4.3.1, I built RTEMS using the
following options:
../rtems/configure --target=bfin-rtems --disable-posix --disable-networking
--enable-rtemsbsp=eZKit533 --disable-itron --prefix=$PWD --enable-tests
The footprint I get for minimum.exe is surprisingly large (when compared to
say the m68k port):
   text    data     bss     dec     hex filename
  53152    2344  595832  651328   9f040 minimum.exe
I poked around in the code and found that the linker cmds are reserving 512K
for the RTEMS workspace in .bss:
        _WorkspaceBase = .;
        . += 512K;      /* reserve some memory for workspace */
I'm new to RTEMS, and so I don't know what the workspace is used for, but I
don't see other targets (e.g., m68k) reserving this much memory.
Is a 512K workspace really required for the bfin port? Can we make it
smaller?
Thanks!
Regards, Devin
URL: <http://lists.rtems.org/pipermail/users/attachments/20080817/06113fdb/attachment.html>
