disable newlib
ray rayx.cn at gmail.com
Mon Aug 18 15:42:22 UTC 2008
I think you can wait for a few more days on YanMiao's patch and have a
try.  It may not the exact one you want, but it can save you some extra
work. And, it has been test with sptest and tmtest.
As Joel said, the patch dose not disable the newlib, but it remove some
unnecessary linkage when generating the binary.
> Manuel Coutinho
> Software Engineer - Space
>   cid:image002.jpg at 01C7EEE1.32B7B120
> EDISOFT, S.A.
> Rua Quinta dos Medronheiros - Lazarim
> Apartado 382 Monte de Caparica
> 2826-801 Caparica Portugal
>> -----Original Message-----
>> From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
>> Sent: Monday, August 18, 2008 4:02 PM
>> To: Manuel Coutinho
>> Cc: 'Joel Sherrill'; 'xu ray'; rtems-users at rtems.com
>> Subject: RE: disable newlib
>> On Mon, 2008-08-18 at 15:57 +0100, Manuel Coutinho wrote:
>>> Hi
>>> We are trying to make possible a configuration (using the configure
>> script)
>>> where RTEMS does not have newlib (open, close, malloc, etc) and other
>> things
>>> so that a minimal footprint can be achieved.
>>> At this stage, we are just checking how much effort is required to
>> perform
>>> this. I would suggest to place #ifdef inside the RTEMS source code so
>> that
>>> the unnecessary calls are not made. However, there is more work needed
>> here.
>>> I've tried to take out most of the calls to libc and other things that
>> we
>>> don't need from the RTEMS source code (e.g rtems_termios_init, etc) and
>> the
>>> footprint has been reduced from ~70 KiB to ~37KiB, but we need to go
>> further
>>> and remove all dead code. Since RTEMS itself makes calls to newlib or
>> libc,
>>> if the application does not make the extra calls it is not sufficient
>>> because the code will still be present.
>> What you are missing: GCC emits calls to newlib.
> Yes, I forgot to mention this. There are some calls to open, close, etc.
>>> Now, we stumbled with the newlib source code that is very intertwined
>> with
>>> RTEMS (mainly to make malloc reentrant, from what I can tell). This will
>>> need some detailed research to make sure everything works well.
>> Good luck - To me your plan is nothing but silly.
Thanks&  Best Regards
---Ray
