Ping stress (>=990 bytes)
Gene Smith gds at chartertn.net
Mon Aug 18 19:42:55 UTC 2008
Keith Robertson wrote:
> Gene Smith wrote:
>> Another question on dropped packets. I am able to ping (even flood ping)
>> up to a length of 980 bytes with no loss. When I go over this my tcp/ip
>> stack seem to go bad. Regular pings (56 bytes) sometimes don't respond,
>> or responds with a huge amount of data (1022 bytes). Is there a maximum
>> ping length in rtems?  I see no bad stats in netdemo. My (newly made)
>> driver has buffers for 1536 bytes.
>> Wondering if others can ping the rtems stack with >=990 bytes?
> On rtems 4.8.1 (and earlier as well), I can successfully ping rtems
> devices with packets of 65507 bytes (the icmp max).  It takes longer,
> but it works fine.
> This is on the powerpc/virtex bsp.
> Keith
Thanks for verifying this. Had a problem in the driver where the send
length wasn't being initialized right. Also, needed to allocate more
receive/xmit buffers in the driver to receive/send 65507 byte frames. So
now I can ping with -s 65507. Looks pretty good!
-gene
