CVS Head Slushy, Please Test and Fix Warnings
    Chris Johns
    chrisj at rtems.org
    Thu Aug 21 07:07:56 UTC 2008
Sebastian Huber wrote:
> Andrei Chichak wrote:
>>> Please build the BSPs you use, fix warnings
>>> and other issues.  Then report whether they
>>> can run tests or not.
>> I figured that I would give it a go. I got CVS going, grabbed the
>> distribution, fired up MINGW and bootstrap blows since it needs
>> autoconf 2.62. I grabbed the latest tools (17), installed them, but
>> it still contains autoconf 2.61. No joy.
> I followed the instructions in
> http://wiki.filezilla-project.org/Compiling_FileZilla_3_under_Windows#Autotools
> I installed M4 version 1.4.7 from the linked Sourceforge site.
> Afterwards I configured Autoconf 2.62 and Automake 1.10.1 (downloaded
> from GNU server) via 'configure --prefix=/opt/rtems-4.9' and installed
> them directly into the RTEMS tree. With that done I was able to build
> the current RTEMS CVS version from scratch.
Ah yes I need to fix this and spin a new version. I had forgotten about this
little problem.
Regards
