Bug of libcsupport open?
Fri Aug 22 13:42:28 UTC 2008
Wei Shen wrote:
> Hi,
> If "iop->handlers->open_h" returns an error, "open" will call
> "rtems_set_errno_and_return_minus_one( rc )" which sets "errno" to
> "rc", where "rc" is the return value of "open_h".
> However, the "open_h" handler implemented by each filesystem usually
> already sets "errno" and returns only -1 at errors, so "open" will
> override "errno" with -1 which is not a valid errno.
I think you are correct.  And my scan of the open implementations
in cpukit/libfs indicates a possible mix in returns.
I think open() should assume -1 returned and errno set.  This
makes it up to the specific handlers to do the right thing.
Do you have a patch?
> Regards,
> Wei
