Problem building gcc 4.3.1 cross-compiler with ada
Dirk Heinrichs dirk.heinrichs at online.de
Sat Aug 23 09:54:56 UTC 2008
Am Donnerstag, 21. August 2008 18:39:37 schrieb Dirk Heinrichs:
> Am Mittwoch, 20. August 2008 21:27:28 schrieb Joel Sherrill:
> > > just wanted to ask wether there is any news about this problem.
> > I've been building and testing off the GCC SVN trunk
> > and RTEMS head with no problems.
> OK, I'll try that.
Just found the solution to my problem. I had a native gnatgcc installed and
$ADA_INCLUDE_PATH was set to that installation. After unsetting all ADA
related env variables in the shell where I built the toolchain everything
built just fine with gcc 4.3.1.
Bye...
	Dirk
