Build Problems
Madhusudan C.S
madhusudancs at gmail.com
Sun Aug 24 18:10:17 UTC 2008
Hi Joel,
Standard questions and advice. Build outside the source tree. You probably
> only
> want to build 1 BSP and are building many. You might be out of disk space
> given
> that.
> Make sure you have the RTEMS autoconf and automake installed and at the
> FRONT of your PATH.
> cd rtems
> ./bootstrap
> cd ..
> mkdir b-sis
> cd b-sis
> ../rtems/configure --target=sparc-rtems4.9 --enable-rtemsbsp=sis \
> --enable-tests=samples --prefix=SOME_DIRECTORY
> make
> That should work.
Thanks a lot for the reply. This is the PATH I have set
madhu at madhusudan:/media/professional/rtems/b-sis$ echo $PATH
/opt/rtems-4.9/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
And everything is done as you said. But still getting the same error.
Thanks and regards,
Madhusudan.C.S
Blogs at: www.madhusudancs.info
URL: <http://lists.rtems.org/pipermail/users/attachments/20080824/fdcf14de/attachment.html>
