A simple question about porting rtems to a new BSP
    Tim Cussins
    timcussins at eml.cc
    Wed Aug 27 14:03:02 UTC 2008
On Wed, 2008-08-27 at 21:38 +0800, PowerMan wrote:
> Hello,
>        I am working for a IC company. My work is porting rtems to
> vt3421.
> VT3421 is a security chip based on arm926ej-s. That chip is designed
> by my company.
>        I create 2 directory:
> rtems-4.7.3/c/src/lib/libcpu/arm/vt3421
> rtems-4.7.3/c/src/lib/libbsp/arm/vt3421-board
Hi PowerMan.
RTEMS has extensive documentation:
http://www.rtems.com/onlinedocs/doc-current/share/rtems/html/
The doc you might want to look through is:
RTEMS BSP and Device Driver Development Guide
You'll probably kick off by copying the folder (& contents) for a bsp that uses the same processor, then tweak as required.
Tim
