skyeye 1.2.5 and Various BSPs
xu ray rayx.cn at gmail.com
Thu Aug 7 13:34:17 UTC 2008
I have check the codes in svn of skyeye, it does not support SAM family.
2008/8/7 Joel Sherrill <joel.sherrill at oarcorp.com>
> Bassem Fahmy wrote:
> > Hi All,
> > can a sam7 bsp be simulated on SKyeye? what is the configuration file.
> This is best asked of a Skyeye expert. All of the Skyeye configuration
> files I have used were given to us.
> This is the current list of supported ARM machines. I have cc'ed
> Michael Kang hoping he has a better answer.
> -------- ARM architectures ---------
> at91
> lpc
> s3c4510b
> s3c44b0x
> s3c44b0
> s3c3410x
> ep7312
> lh79520
> ep9312
> cs89712
> sa1100
> pxa_lubbock
> pxa_mainstone
> at91rm92
> s3c2410x
> s3c2440
> sharp_lh7a400
> ns9750
> > Thanks
> > > Date: Wed, 6 Aug 2008 22:39:24 +0800
> > > From: hiyangxi at gmail.com
> > > To: joel.sherrill at oarcorp.com; rtems-users at rtems.org
> > > Subject: Re: skyeye 1.2.5 and Various BSPs
> > > On Tue, Jul 29, 2008 at 9:26 PM, Joel Sherrill
> > > <joel.sherrill at oarcorp.com> wrote:
> > > > xi yang wrote:
> > > >> I have a auto-test Gumstix BSP for RTEMS. I will submit it this
> week.
> > > > That runs on real HW and Skyeye?
> > > Hi Joel:
> > > Yeah, it runs on real hardware and skyeye.
> > > But I want to make this BSP to be a special BSP for skyeye simulator.
> > > Because I add a shutdown GPIO to skyeye simulator. And do you remember
> > > that my summer code proposal is about auto-test, network and LCD
> > > support BSP for Skyeye simulator. So I want to complete this project.
> > > At this stage, auto-test works fine. Next steps are network and LCD
> > > support.
> > > Another thing is that could I upload the 'RTEMS on L4' to the site of
> > > RTEMS? 'RTEMS on L4' is my undergraduate thesis. Maybe some guys want
> > > to play with it.
> > > > Yeah! Please submit. I will be unavailable some this week
> > > > so don't fret if I don't reply quickly.
> > > >> Regards
> > > >> On Tue, Jul 29, 2008 at 7:10 AM, Joel Sherrill
> > > >>> Hi,
> > > >>> This is IMPORTANT so if you can help at all,
> > > >>> it is needed. This is an attempt to broaden
> > > >>> the automated testing as we finalize a release.
> > > >>> I have spent some time over the past few days
> > > >>> trying to get scripts together so we could
> > > >>> use Skyeye 1.2.5 as an automated test platform
> > > >>> for a variety of BSPs. In doing so, I have
> > > >>> found a number of problems and need help
> > > >>> from a variety of BSP folks.
> > > >>> + arm/edb7312 - fine on 4.8, ticker gives SKYEYE
> > > >>> error on 4.9
> > > >>> + arm/csb336 - locks on both 4.8 and 4.9
> > > >>> waiting for clock tick
> > > >>> + arm/rtl22xx - fine on 4.8, ticker gives SKYEYE
> > > >>> error on 4.9
> > > >>> + bfin/eZKit533 - doesn't run on either 4.8 or 4.9.
> > > >>> If you have a BSP on Skyeye I didn't mention,
> > > >>> please speak up. I would really like a coldfire
> > > >>> BSP on a simulator.
> > > >>> If you can fix one of the above or have some insight,
> > > >>> please speak up. Better if you can fix something.
> > > >>> Joel Sherrill, Ph.D. Director of Research & Development
> > > >>> joel.sherrill at OARcorp.com On-Line Applications Research
> > > >>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> > > >>> Support Available (256) 722-9985
> > > >>> _______________________________________________
> > > >>> rtems-users mailing list
> > > >>> rtems-users at rtems.com
> > > >>> http://rtems.rtems.org/mailman/listinfo/rtems-users
> > Get Windows Live and get whatever you need, wherever you are. Start
> > here.
> > <http://www.windowslive.com/default.html?ocid=TXT_TAGLM_WL_Home_082008>
Thanks & Best Regards!
Ray, Xu
URL: <http://lists.rtems.org/pipermail/users/attachments/20080807/fd785e54/attachment-0001.html>
