Proposed ARM Tool Change After 4.9
xu ray
rayx.cn at gmail.com
Thu Aug 7 14:50:53 UTC 2008
I think it might be a good news that the eabi have thumb-2 feature (So that
we do not need to maintain a seperate thumb-2 toolchain in future)
Though it sounds like has no big impact on our ARM bsp, but it would still
be good to keep both arm-elf and arm-eabi at first in case eabi has some
defect/incompatible.
2008/8/7 Joel Sherrill <joel.sherrill at oarcorp.com>
> Hi,
> After posting my first gcc test results for
> arm-rtems, I got feedback which indicates
> that arm-eabi is the preferred arm embedded
> target (not arm-elf).
> arm-rtems is based upon arm-elf. I propose
> we switch to being based upon arm-eabi for 4.10.
> Attached are Paul Brook's comments on the
> impact of the change.
> Comments, thoughts, etc?
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> > We chose arm-elf as the starting point years. If we need to
> > move to arm-eabi as the starting point that is OK. We usually
> > just chose the CPU-coff or CPU-elf as a starting point
> > for CPU-rtems.
> I highly recommend switching to the EABI.
> If you want to support recent (Thumb-2) CPUs I'd expect that you pretty
> much
> have to use an EABI based target.
> > What is the difference and how will it impact code? I am
> > worried about our assembly code.
> The main visible change is that that you must preserve 8-byte stack
> alignment
> at public entry points.
> > Is there a standard conditional to know the difference if
> > it matters?
> __ARM_EABI__
> Paul
> rtems-users mailing list
> rtems-users at rtems.com
Thanks & Best Regards!
Ray, Xu
URL: <http://lists.rtems.org/pipermail/users/attachments/20080807/7f130e7f/attachment-0001.html>
