RTEMS version: 4.6.5-1.0.19 pci bug?
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Aug 11 16:07:30 UTC 2008
Aitor.Viana.Sanchez at esa.int wrote:
> Hi all,
> I think I found a bug in the pci_allocate_resources() RTEMS function.
> We are working with RTEMS for leon2 processor, and writing drivers for
> some other PCI boards we discovered a bad behaviour in the init_pci()
> function.
This is a Gaisler specific version number and until 4.8 I don't
see pci.c under bsp/sparc at all.
> Source file affected: pci.c
> Path: rtems-4.6.5/c/src/lib/libbsp/sparc/leon2/pci
> Affected functions:
> * void pci_allocate_resources(void)
> *Modification description*
> /void pci_allocate_resources(void)/.
> *Lines: 472 and 563*
> Substitute the line:
> *if (size == 0 || size == 0xffffffff || (size & 0x3f1) != 0) {*
> by the line:
> *if ((size == 0 || size == 0xffffffff) != 0) {*
This line only appears once in the version in RTEMS CVS for leon2 and
it has not been changed since it was merged in September 2007. It reads:
if (size == 0 || size == 0xffffffff || (size & 0xff) != 0) {
Jiri/Daniel... any thoughts?
> In our PCI boards, the bits 3:0 of the BAR1 address are hardcoded to
> "1000" and the (size & 0x3f1) statement made the condition to be false
> always. The change does not affect the rest of boards we had already
> working. The reason why this condition is set in the original "pci.c"
> file is not clear and is not documented (maybe Jiri may say some).
> I didn't have a look, but maybe this also affects to RTEMS 4.8 and
> RTEMS 4.9 and maybe not only leon2 code but also leon3.
> //avs
> Aitor Viana Sánchez
> ESA - European Space Technology Centre (ESTEC)
> TEC-EDD - Computer and Data Systems Section
> ESA/ESTEC P.O. Box 299 / 2200AG Noordwijk ZH, The Netherlands
> Tel (+31) 71 565 6727
> Email: aitor.viana.sanchez at esa.int
