disable newlib
    xu ray
    rayx.cn at gmail.com
    Mon Aug 18 14:12:31 UTC 2008
You can disable it with patch YanMiao is working on.
But after doing this, lots of API (e.g. Posix ) and (most) C library can not
be used.
You can use this for small footprint MCU/CPU that has limited RAM on chip.
2008/8/18 Manuel Coutinho <manuel.coutinho at edisoft.pt>
>  Hi
> Just a quick question:
> How can we disable newlib (I mean, undefine RTEMS_NEWLIB)? Can this be done
> in the configuration phase?
> Thanks
> *Manuel Coutinho
> *Software Engineer - Space
> *EDISOFT, S.A.*
> Rua Quinta dos Medronheiros - Lazarim
> Apartado 382 Monte de Caparica
> 2826-801 Caparica Portugal
> rtems-users mailing list
> rtems-users at rtems.com
Thanks & Best Regards!
Ray, Xu
URL: <http://lists.rtems.org/pipermail/users/attachments/20080818/f55831fb/attachment-0001.html>
