On Mon, 2008-08-18 at 09:37 -0500, Joel Sherrill wrote: > xu ray wrote: > > You can disable it with patch YanMiao is working on. > I don't see how you can disable the entire newlib library without > special tool builds. Correct, you would have to use a plain metal toolchain instead of the RTEMS toolchains.
