error: conflicting types for 'gettimeofday'
João Craveiro jcraveiro at lasige.di.fc.ul.pt
Fri Feb 1 13:30:18 UTC 2008
Thank you. That tarball would be welcome, too (the project in which I am
using RTEMS could well use that kind of way to guarantee that everyone
involved has the same code), so thanks for that too.
João Craveiro
Ralf Corsepius wrote:
> On Wed, 2008-01-30 at 18:32 +0000, João Craveiro wrote:
>> Hi there,
>> I am trying to build RTEMS 4.7.99.2 both on Fedora 6 and Fedora 8 boxes
>> (following the instructions in
>> http://www.rtems.com/wiki/index.php/Quick_Start), and I get the same
>> error as stated here:
>>      http://www.rtems.com/ml/rtems-users/2008/january/msg00017.html
>> ../../../../../../rtems-4.7.99.2/c/src/../../cpukit/libcsupport/src/__gettod.c:40:
>> /opt/rtems-4.8/lib/gcc/sparc-rtems4.8/4.2.2/../../../../sparc-rtems4.8/include/sys/time.h:73:
>> error: previous declaration of 'gettimeofday' was here
>> The tools installed are the latest RPMs from the Yum repository.
>> Any hints? Thanks in advance,
> Update your RTEMS sources (e.g. from rtems-4-8-branch in RTEMS CVS).
> The declaration of gettimeofday() in sys/time.h had been changed to
> comply with POSIX, but your version of RTEMS still contains the old
> (non-POSIX compliant) version of it.
> @Joel: Do we have a snapshot tarball from rtems-4-8-branch, which has
> these changes inside? I don't think so.
> Ralf
