-qleon2 for pre-built sparc-rtems4.7-gcc?
Jiri Gaisler jiri at gaisler.com
Mon Feb 4 14:49:50 UTC 2008
The standard RTEMS tool-chain uses makefiles and shell variables
to set the include and lib paths. This is documented in the RTEMS
docs. The Gaisler version of the tool-chain uses a modified gcc
specs file to define the paths.
Jiri.
Ingolf Steinbach wrote:
> Hi
> when using the sparc-rtems-gcc provided by Gaisler for RTEMS 4.6 on
> leon2, I just had to supply -qleon2 on the command line in order to
> automatically add the BSP specific include and library paths.
> In contrast to that, the pre-built tools for 4.7.1 from ftp.rtems.org
> seem not to recognize the -qleon2 switch. Is there some magic (besides
> including extra make files) to tell sparc-rtems4.7-gcc where to find
> the bsp-specific include and library paths?
> Kind regards
> Ingolf
> rtems-users mailing list
> rtems-users at rtems.com
