New driver inclusion on RTEMS 4.7.99.2
Mon Feb 4 17:20:22 UTC 2008
Aitor Viana wrote:
> Hi all,
> I am trying to include a new driver for the leon2 bsp, and I don't
> success because I think I am missing steps.
> - In the src/rtems-4.8/c/src/lib/libbsp/sparc/leon2 folder I have
> created a new folder, lets call this folder newdriver with a new file
> newdriver.c
> - then, in the src/rtems-4.8/c/src/lib/libbsp/sparc/leon2/Makefile.am
> I have added
> # NEWDRIVER
> noinst_PROGRAMS newdriver.rel
> newdriver_rel_SOURCES = newdriver/newdriver.c
> newdriver_rel_CPPFLAGS = $(AM_CPPFLAGS)
> newdriver_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
> libbsp_a_LIBADD = startup.rel console.rel clock.rel timer.rel
> gnatsupp.rel \
>                   amba.rel rasta.rel uart.rel spw.rel can.rel brm.rel
> pci.rel \
>                   cchip.rel newdriver.rel
> then I, in the src directory, I run:
> /> ./bootstrap
> /> make configure
> /> make compile
> But looking into the build directory I don't find anything regarding
> newdriver.
> Am I missing something?
When you are doing this type of modification your build tree
must have been configured with --enable-maintainer-mode.
You can also remove the build tree and try it again.
It doesn't appear that you missed anything obvious other than that.
> Thanks in advance.
> Aitor
