Problem using bsp leon2 on rtems 4.7.1
Aitor Viana
aitor.viana.sanchez at esa.int
Wed Feb 6 08:47:28 UTC 2008
Hi,
please someone correct me if I forgot something. You've got to add both the
source .c and the header .h file into the Makefile.am. Then bootstrap,
configure, etc, etc.
This should be enough, however, I also have to perform a make clean to
remove the build tree because otherwise the procedure is not well done.
Cheers,
Aitor
On Wed, Feb 6, 2008 at 9:38 AM, Arquer Stephane <stephane.arquer at c-s.cnes.fr>
wrote:
> Hi,
> I'm again trying to work with the bsp leon2, my problems are:
> - when I compile the sample "hello.c" with the bsp leon provided by rtems
> v4.6.6, the execution starts on our leon2 target.
> When I do the same with the leon2 bsp of the rtems v 4.7.1 the program
> doesn't start. The initialisation seems to be different, the program crash
> with the error:
> IU error mode (tt = 0x09)
> 400714ec c2024000 ld [%o1], %g1
> Does anyone know how to correct it ?
> - when I want to add new drivers to the standard bsp, some header files
> are placed in the folder new_bsp/include.
> Then I run bootstrap script in the new_bsp folder, I run configure with
> --enable-maintener-mode to add the new .rel.
> But during the make, the new header file are not found, I have to copy
> them manually to continue.
> Is there something wrong In the way I proceed ?
> Thanks ahead.
> Stéphane.
> rtems-users mailing list
> rtems-users at rtems.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20080206/e8834053/attachment.html>
