netdemo
Tue Feb 19 15:02:41 UTC 2008
朱旭峰 wrote:
> Hi all:
> when I tested the netdemo , it happend nothing after the console
> printed the route information
> and "Create socket" " Bind socket " "Listen" " Accept ".
> I used gdb to find out that the routine run to
> rtems_event_receive (SOSLEEP_EVENT, RTEMS_EVENT_ANY | RTEMS_NO_WAIT,
> RTEMS_NO_TIMEOUT, &events);
> which is in function soconnsleep.
> Anyone can give some advices?
There is a README in the test which explains what you
should do.
> Thanks
