SPI low level driver for Virtex
Robert S. Grimes rsg at alum.mit.edu
Fri Feb 22 22:21:06 UTC 2008
Thomas Doerfler wrote:
>> Okay, I'm starting by grabbing the updated libi2c, which probably is
>> straightforward enough.
>> Then, I copied the "real" driver from libcpu/mpc83xx/spi and
>> libbsp/powerpc/gen83xx into libbsp/powerpc/virtex/spi.  Next I will
>> adapt these files for the Virtex 4 chip. This shouldn't be too hard,
>> what with an RTEMS driver example and the Xilinx programming example
>> to work from.
> right, the most difficult thing might be to not get confused with the
> slightly unusual names of some SPI driver functions. Remember: I2C was
> there first, therefore some SPI function names are derived from the
> I2C stuff.
Right!
>> I'm almost certainly going to need help with the automake stuff.
>> Should I just diff before and after your SPI additions, and try to
>> recreate?
> - in cpukit/*, automake should already be fine.
> - for libchip, if you pulled the more or less current version from
> CVS, things should be fine aswell (hopefully you do not merge
> Makefile.am from different CVS versions, this MIGHT cause trouble)
> - for the virtex BSP: You will have to add the spi driver in a similar
> way as the spi (spi_init) stuff in libbsp/powerpc/gen83xx. If you grep
> for spi (and SPI) there, you should find the relevant portions.
I think I already figured that out, but thanks for the confirmation.
>> And I'm not sure what I will need to do to build the thing.  Will I
>> just type make, or do I need to run configure first?  (I have
>> previously specified --enable-maintainer-mode, if that helps).  If I
>> do have to configure, can (and how can) I run it just on the
>> libbsp/powerpc/virtex tree?
> Enabling the "maintainer-mode" should do most of the stuff. In the
> past, some "preinstall.am" files (responsible to copy header files and
> stuff in place) were not always regenerated, if neccesary, so it might
> be usefull to run "../../../bootstrap -p" in your BSP directory.
Thanks for the tip!
>>> The EEPROM driver has more or less a standard rtems driver API.
>> I'm going to adapt the same approach here - copy, rename, and edit.
>> I'm not sure (again) how I get it built - another reconfig?
> The same applies here.
> By the way: You wrote you would need a driver for a SPI Ramtron
> memory. I actually "virtualized" the spi-flash*.c driver to be
> adaptable to memory devices with similar interface, I already use it
> for a FM24L256. So I would recommend to write the the ADC driver
> first, and wait 'til I can update the CVS...)
Okay, thanks!  I do like those Ramtron FRAM chips!
Have a great weekend.
-Bob
> wkr,
> Thomas.
>> Thanks,
>> -Bob
