MinGW useage (Re: RTEMS 4.8.0 Available)
Mon Feb 25 15:06:08 UTC 2008
Smith, Gene SEA wrote:
> I failed to prefix the "make all" with "sh" which got rid of the popup
> errors.
I couldn't build psim on mingw with the 4.8.0 tarball.
I did a "bootstrap -c ; bootstrap" and then the build worked.
I bootstrapped the tarball on Fedora 8 so maybe that is
enough of a hint for Chris to comment.
> However, still evenutally fails running the "compile" wrapper:
> mv -f ../../libbsp/arm/shared/irq/.deps/at91rm9200_irq_rel-irq_asm.Tpo
> ../../libbsp/arm/shared/irq/.deps/at91rm9200_irq_rel-irq_asm.Po
> /opt/rtems-4.8/rtems-4.8.0/compile arm-rtems4.8-gcc --pipe
> -B../../../../.././lib/ -B../../../../.././csb337/lib/ -specs bsp_specs
> -qrtems -Wall -mcpu=arm920 -m
> structure-size-boundary=8  -O2 -g  -qnolinkcmds -nostdlib -Wl,-r  -o
> at91rm9200/irq.rel at91rm9200/irq/at91rm9200_irq_rel-irq.o
> l-bsp_irq_init.o
> ../../libbsp/arm/shared/irq/at91rm9200_irq_rel-irq_init.o
> at91rm9200/irq/at91rm9200_irq_rel-bsp_irq_asm.o
> 0_irq_rel-irq_asm.o
> arm-rtems4.8-gcc.exe: at91rm9200/irq/at91rm9200_irq_rel-bsp_irq_asm.o:
> No such file or directory
> ../../libbsp/arm/shared/irq/at91rm9200_irq_rel-irq_asm.o: No such file
> or directory
> It appears that this "compile" wrapper has somthing to do with compilers
> that don't support both -o and -c which is the same subject as the
> failures before.
> rtems-users mailing list
> rtems-users at rtems.com
