Rtems 4.8.0 / Mingw / Coldfire Gcc Bug
Fri Feb 29 08:54:45 UTC 2008
Paul Whitfield wrote:
> I just attempted to build rtems 4.8.0 multi lib with the Mingw tools,
> However, it stops with a gcc internal compiler error ala
> http://gcc.gnu.org/bugzilla/show_bug.cgi?id=34439
> Any suggestions?
It is suppose to be fixed in the latest gcc. Ralf has confirmed this how-ever
these tool sets are not available to download.
I have not looked to see if the code can be changed to work around the bug. If
a work around is found it might be worth considering for the 4.8.0 branch.
Regards
