Rtems 4.8.0 / Mingw / Coldfire Gcc Bug
Fri Feb 29 11:55:19 UTC 2008
Ralf Corsepius wrote:
> On Fri, 2008-02-29 at 19:54 +1100, Chris Johns wrote:
>> Paul Whitfield wrote:
>>> I just attempted to build rtems 4.8.0 multi lib with the Mingw tools,
>>> However, it stops with a gcc internal compiler error ala
>>> http://gcc.gnu.org/bugzilla/show_bug.cgi?id=34439
>>> Any suggestions?
>> It is suppose to be fixed in the latest gcc.
> AFAICT, this bug is present in all GCC releases from GCC's 4.2.x release
> series. I am not aware about any fix to it (c.f. the BZ above).
Ok.
>>  Ralf has confirmed this how-ever
>> these tool sets are not available to download.
> This bug seems to be fixed in GCC's 4.3.x release series, which is
> supposed to be released in "not to distant future".
> At least, I can't reproduce the breakdown with toolchains having been
> built from development versions/release candidates from this series.
> BTW: I pushed rtems-4.9-GCC Linux rpms having been built from GCC-4.3.0
> release candidate tarballs, which also should be suitable to build
> rtems-4.8.
Great. Is this in CVS ? Is this on HEAD ?
Regards
