Can't Build New Device Driver
Robert S. Grimes
rsg at alum.mit.edu
Fri Feb 29 18:41:22 UTC 2008
Sebastian Huber wrote:
> Hi,
> I struggle with the BSP development currently too.
I feel your pain!
> A "bootstrap -p" in the top level source directory may fix your problem.
I had tried this in my bsp directory only already...
> It was helpful to add RTEMS_AMPOLISH3 to the configure.ac since this adds a rule to update the preinstall.am file if you have enabled the maintainer mode.
I have no idea how to do this...
> I also added "BUILT_SOURCES = preinstall" to the Makefile.am as a workaround to enforce a preinstall during "make all" in subdirectories.
Not sure where to put this, or if it matters where, but I did so
Results: I added "BUILT_SOURCES = preinstall" and then did a full
"bootstrap -p", then a "make all", and it still doesn't work.
Attached (really!) is a bz2 of the current Makefile.am and Makefile.in -
can anyone help?
Thanks, and take care,
-Bob
> Ciao,
> Sebastian
> Robert S. Grimes wrote:
>> make[8]: Entering directory
>> `/cygdrive/c/Home/ll/etill/rtems/rtems-4.8.0/tools/b-rtems/powerpc-rtems/c/virtex/lib/libbsp
>> /powerpc/virtex'
>> make[8]: *** No rule to make target `preinstall'. Stop.
>> make[8]: Leaving directory
>> `/cygdrive/c/Home/ll/etill/rtems/rtems-4.8.0/tools/b-rtems/powerpc-rtems/c/virtex/lib/libbsp/
>> powerpc/virtex'
>> make[7]: *** [preinstall-recursive] Error 1
>> make[7]: Leaving directory
>> powerpc'
>> I don't have any idea what the error message means, other than the
>> obvious! Attached are my Makefile.am and the generated Makefile.in for
>> your reference.
>> Thanks,
>> -Bob
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
> embedded brains GmbH
> Sebastian Huber Obere Lagerstr. 30
> D-82178 Puchheim Germany
> Tel. : +49-89-18 90 80 79-6
> Fax : +49-89-18 90 80 79-9
> email: Sebastian.Huber at embedded-brains.de
> PGP public key available on request
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20080229/2fa2dd2a/attachment.obj>
