Action of rtems_message_queue_send
Fri Feb 15 14:57:44 UTC 2008
Andrei Chichak wrote:
> When sending a message to a queue, does the message data get copied
> into the message queue or does the queue point at the original data items?
> The reason that I ask is that if the data is not copied, alteration
> of the message data items before the message gets received will pick
> up the new values. (I've seen this in another /OS )
Read this page from the manual and see if it answers your
question.
http://www.rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/c_user00182.html
If it doesn't then the documentation is broken and I need
to clarify it.
> Andrei
> rtems-users mailing list
> rtems-users at rtems.com
