SPI low level driver for Virtex
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Fri Feb 22 19:35:12 UTC 2008
Robert,
Robert S. Grimes schrieb:
> Hi Thomas,
> How was the skiing?!
oh, what a question it seems SOOOOO long ago, sigh.
But it was fantastic. We really had a very nice week together and the
kids used the available WLAN more often than I :-)
> Okay, I'm starting by grabbing the updated libi2c, which probably is
> straightforward enough.
> Then, I copied the "read" driver from libcpu/mpc83xx/spi and
> libbsp/powerpc/gen83xx into libbsp/powerpc/virtex/spi. Next I will
> adapt these files for the Virtex 4 chip. This shouldn't be too hard,
> what with an RTEMS driver example and the Xilinx programming example to
> work from.
right, the most difficult thing might be to not get confused with the
slightly unusual names of some SPI driver functions. Remember: I2C was
there first, therefore some SPI function names are derived from the I2C
stuff.
> I'm almost certainly going to need help with the automake stuff. Should
> I just diff before and after your SPI additions, and try to recreate?
- in cpukit/*, automake should already be fine.
- for libchip, if you pulled the more or less current version from CVS,
things should be fine aswell (hopefully you do not merge Makefile.am
from different CVS versions, this MIGHT cause trouble)
- for the virtex BSP: You will have to add the spi driver in a similar
way as the spi (spi_init) stuff in libbsp/powerpc/gen83xx. If you grep
for spi (and SPI) there, you should find the relevant portions.
> And I'm not sure what I will need to do to build the thing. Will I just
> type make, or do I need to run configure first? (I have previously
> specified --enable-maintainer-mode, if that helps). If I do have to
> configure, can (and how can) I run it just on the libbsp/powerpc/virtex
> tree?
Enabling the "maintainer-mode" should do most of the stuff. In the past,
some "preinstall.am" files (responsible to copy header files and stuff
in place) were not always regenerated, if neccesary, so it might be
usefull to run "../../../bootstrap -p" in your BSP directory.
>> The EEPROM driver has more or less a standard rtems driver API.
> I'm going to adapt the same approach here - copy, rename, and edit. I'm
> not sure (again) how I get it built - another reconfig?
The same applies here.
By the way: You wrote you would need a driver for a SPI Ramtron memory.
I actually "virtualized" the spi-flash*.c driver to be adaptable to
memory devices with similar interface, I already use it for a FM24L256.
So I would recommend to write the the ADC driver first, and wait 'til I
can update the CVS...)
wkr,
Thomas.
> Thanks,
> -Bob
embedded brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
Tel. : +49-89-18 90 80 79-2
Fax : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
