Rtems 4.8.0 / Mingw / Coldfire Gcc Bug
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Feb 29 15:23:02 UTC 2008
Ralf Corsepius wrote:
>>> On Fri, 2008-02-29 at 19:54 +1100, Chris Johns wrote:
>>>> Paul Whitfield wrote:
>>>>> I just attempted to build rtems 4.8.0 multi lib with the Mingw tools,
>>>>> However, it stops with a gcc internal compiler error ala
>>>>> http://gcc.gnu.org/bugzilla/show_bug.cgi?id=34439
>>>>> Any suggestions?
>>>> It is suppose to be fixed in the latest gcc.
>>> AFAICT, this bug is present in all GCC releases from GCC's 4.2.x release
>>> series. I am not aware about any fix to it (c.f. the BZ above).
>>>> Ralf has confirmed this how-ever
>>>> these tool sets are not available to download.
>>> This bug seems to be fixed in GCC's 4.3.x release series, which is
>>> supposed to be released in "not to distant future".
>>> At least, I can't reproduce the breakdown with toolchains having been
>>> built from development versions/release candidates from this series.
>>> BTW: I pushed rtems-4.9-GCC Linux rpms having been built from GCC-4.3.0
>>> release candidate tarballs, which also should be suitable to build
>>> rtems-4.8.
>> The tools may be OK but from the 4.8 branch itself will
>> need a number of minor changes made to compile and link
>> cleanly with 4.3.x. I need to review my build logs before
>> committing but I edited about ~75 files yesterday to
>> address 4.3.x issues. That ignores the miscellaneous
>> limits.h changes you and I both have made over the past
>> few weeks.
>> If the community wants to move to gcc 4.3.x for the 4.8
>> branch then I have no problem with it. It is definitely better
>> for the Coldfire and long term maintenance. I would
>> be happy to cut a 4.8.1 when the gcc 4.3.0 RPMs are available.
>> For this to happen, I only see a few issues worth addressing:
>> + Fix the locale C++ issue. I see Ralf committed the fix
>> to the issue from a couple of months ago so this will
>> have to be debugged further. :(
>> + Backport the minor changes 4.3.x requires with limits.h,
>> etc. and linkcmds. This is minor and I will go ahead and
>> start committing this type of change to the trunk and 4.8
>> in anticipation.
>> + It would also be highly desirable for the release tarball
>> to be bootstrap'ed on Fedora and work on MS-Windows.
>> I really don't know off hand what patches are missing.
>> That isn't much too aim for in a quick 4.8.1, is it? :-D
> Full d'accord. I am not recommending to switch the rtems-4.8 toolchains
> to gcc-4.3.0.
Are you not wanting to ever switch 4.8 to gcc 4.3 or just
wait until there is a release?
> Gradually backporting fixes to issues (such as my limits.h patches) we
> discover during testing gcc-4.3.0 (gcc-4.3.0 has not even been released
> yet!) definitely is desirable.
I think so. The issues appear to be minor so far and mostly
.h file include issues where we got lucky before and linkcmds
on gcc_except_table*.
--joel
> Ralf
